Jarod888
- Dec 19, 2005
I currently have a Thermaltake Armor, the big one, VA8000BWS Black with the side window and all. I like the case except for the fact that i want my harddrives to go across the front of the case instead of lengthwise. I also want a case that is easier for cable management.
I really like the look of the Silverstone TJ07 (SST-TJ07W ) in black with a window. It is quite expensive and I want to make sure that it is a good case. Noise is really not an issue, I have 4 fans AeroCool XtremeTurbine-Black 120mm running at 89 cfm and a 92mm fan running at 50 cfm.
A couple of other questions, are the fans that come with the tj07 good or are my aero cool ones better? I want the most amount of air flow I can get.
Is the upgrade worth it. I woupld probably sell my armor, or I may keep it and use it for another computer later. Are there any special things that I should know? ie tips, tricks, other good ideas when building with this case.
On other thing, I currently have 2 dvd burners, each using 1 IDE slot on my a8n32 sli, and 2 250 gig hd's as slaves on the respective IDE channels. I have 2 400 gig sata drives and a raptor 150 I want to keep this current set up, I might upgrade the size of the ide drives to 320, but that isn't that likely. will the tj07 accomodate this set up with out much modification?
