I think my computer died
Magice
I was using my computer when the internet died, so I did a routine ipconfig release renew, when I heard the sound of my harddrive powering on, then the computer reset. I tried to check the temps but it was running really funny. Restarted a second time and the mouse wouldn't work. The third time worked. I switched it with another computer to test if it was the internet or my computer and it was the internet.
So I plugged my computer back in, and now when it starts up I'm getting a solid long beep multiple times "beeeeeep beeeeeeep beeeeeep" spaced far apart
I believe it is my power supply since its been making grinding noises latley, but I just have to be sure it isn't anything else.
Also, what does that beep code mean?
Thanks [H]
sounds like a psu failure to me but you should google the mobo beeps to see what it says.
Hm I can't seem to figure out my beep codes.. Not understanding. I don't know how many times it actually beeps but so far I've heard 3 long ones. If anyone can help my rig is my sig.
Thanks for the links. I can't wait to trash this ecs board in favor for my p5b deluxe coming in :)
did you buy a whole new core system without figuring out the problem of your current system?
I ordered it before the problem.
I still can't seem to figure it out.
Yes I'd like to get it going. I've ordered a sparkle 400w psu for some of those parts and a 520hx for my new ones.
i phrased my question wrong... which parts are you planning on re-using?
Question: why would a power supply make funny noises? The only mechanical part of power supplies is the fan.
The only thing I can think of that would make noises in your computer are your harddrives, fans, or optical drives - anything that has moving parts.
Motherboards won't give audio warnings for a failed power supply - at least not that I know of.
Theres also noise from the capacitors... a sort of high pitched whine. If you're old, you can't hear it, lol.
I'm hearing impaired. But with hearing aids, I hear pretty well.
But I guess I can't hear capacitor whines :p Hearing aids cannot pick up high pitched noises.
