I think im final
.Wiggles.
If you have any suggestions please feel free to let me know and explain please
Mobo: DFI LANPARTY UT nF4 SLI-DR Expert Socket 939 NVIDIA nForce4 SLI ATX AMD Motherboard - Retail
Case: Antec Performance I P180 Silver Steel ATX Mid Tower Computer Case - Retail
DVD-RW: NEC Silver IDE DVD Burner Model ND-3550A - OEM
HS/Fan: ZALMAN CNPS7000B-CU 92mm 2 Ball Cooling Fan/Heatsink - Retail
Floppy: ALPS Silver 1.44MB 3.5" Internal Floppy Drive - OEM
HD: Western Digital Raptor WD740GD 74GB 10,000 RPM Serial ATA150 Hard Drive - OEM
HD: Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 300 MB/s Hard Drive - OEM
Mem: OCZ 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Platinum System Memory Model OCZ4002048ELDCPE-K - Retail
Monitor: SAMSUNG 997mb-TwoTone Silver-Black 19" CRT Monitor D-Sub - Retail
Mouse: Logitech G5 Laser 931376-0403 2-Tone 6 Buttons 1x Wheel USB Laser Mouse - Retail
PSU: Antec TruePower 2.0 TP2-550 EPS12V ATX12V 550W Power Supply - Retail
CPU: AMD Athlon 64 X2 4400+ Toledo 1GHz FSB Socket 939 Dual Core Processor Model ADA4400CDBOX - Retail
SC:Creative Sound Blaster X-Fi XtremeMusic 8 (7.1) Channels PCI Interface Sound Card - Retail
GPU: Leadtek WinFast PX7800GTX TDH myVIVO Extreme 256MB GDDR3 PCI Express x16 Video Card - Retail
everything looks good except your cpu heatsink.
i would get something beefier for the dual core.
i've gathered from what i've read on the forums that the 7000 doesnt do so hot with dual cores, especially if you plan on overclocking some
maybe go with a xp-120, big typhoon, or cnps9500?
I'd recommend getting an Enermax Noisetaker 600w PSU over that Antec one. Antec PSU's are generally pretty weak in my opinion from experience. Don't believe the hype about them, they are certainly nothing special and they will let you down in the long run.
Also, you might wanna look into your case/motherboard selection with regards to compability to whatever heatsink you buy. Some cases and/or motherboards prohibit certain heatsinks due to either capacitors being in the way or the case height being too low.
Just checked out Zalman's website and that Zalman heatsink is compatible with your motherboard:
http://www.zalman.co.kr/product/cooler/7000(AB)_754-939-940MBlist_eng.htm
:cool:
I think im gunna go with the 7700 its cheaper and ive heard it works pretty damn good with the X2's
Has no one been paying attention?
Every heatsink review I have seen shows only one Zalman outperforming the stock X2 heatsink...and thats the 9500. Overclocking or not.
Your wasting your money, go for a good heatsink (as suggested above) or just save your money.
