I think I killed it...
Karant
Just today I bought a brand-new Cooler-Master Centurion 5, to throw my current rig (listed in signature) into. This not being my first time I've switched cases, I quickly got all my peripherals into the new case. However when I plugged in the power, and had not yet turned on the computer, the motherboard started making a loud high-pitch whine, without the power LED on the motherboard turning on. So I had quickly gone on MSN on my secondary computer and asked a bud what he thought was the problem. He had suggested that I most likely fried the motherboard because I did'nt use standoffs. So really, what had I done? If I did fry it, are all the other parts plugged into the motherboard fried? If I take the motherboard out and put standoffs in and try it again, will it work? Thanks.
Take everything out and put in standoffs. You probably shorted out the MB but chances are if you didnt see smoke, sparks, or smell anything burning, you didnt kill anything. Cross your fingers and try again.
sorry nub question buy whats a standoff im thinking of getting the same case soon for my rig and dont want to have the problem u did
make sure there are no extra standoffs under your board. these will short it out. only the standoffs that line up with the holes should be attached to the motherboard tray, and all should have screws.
