okay so i think i clipped my headphones (SRH750DJ)
http://www.amazon.com/Shure-SRH750-DJ-Headphones-Black/dp/B002PAQYK8
i plugged it in the jack of my m audio AV40 and whenever i turn it off the speakers usually pop so last night i turned it off and noticed it didnt pop so i turned it on again and checked my headphones if it made a popping noise if i turned the speakers off. I was greeted with a hard clunk sound as if the drivers hit something. is this bad? should i RMA it? return it to frys or what?
so far its fine. no distortion or any funky sounds that i should be concerned about. i just need advice on what to do.
