I think I broke it
JC419
I updated my BIOS on my 8RDA to try clearing some stuff up. All went well, I used the Alt+F2 option to flash it and everything seemed fine and it booted and ran fine. After doing that I was informed that I should clear the CMOS after flashing the BIOS. I needed to clean my case anyway so I figured it was perfect timing. I cleaned the case and cleared the CMOS with the jumper. After I plugged everything back in, it wouldn't boot. I pulled the side panel off to check the debug thing and it said 'CF.' I looked it up and it said that had to do with CMOS R/W. I tried turning it back on figuring it was a fluke and I got the same 'CF' on the debug thing and then the board started beeping. Did I somehow screw up the BIOS? Is it something I might be able to fix or would I need to send it away?
It could be bios corruption, I haven't had it happen to me ( although i do have a dead 8RDA+ ) but it seemed to be a real problem with NF2 boards when they had just came out and a lot of EPOX NF2 boards were dying from it ( I think Abit boards as well ), Of course i could be overstating the problem but i did see quite a few threads on AMDMB.
Clear it again, then hold the insert key as you power the system on. Continue holding it until it posts.
Clearing the bios is a 2 step process on all nforce2 boards.
If this doesn't help, its time to do some hotflashing.
Just to make sure I don't screw something else up, when I move the CMOS jumper to clear it, do I need to just cap those pins for a few seconds and put it back to normal or do I need to actually power it on for a few seconds? I always thought all you needed to do was cap them pins for a few seconds and that was fine. Also, what is this hotflashing you speak of?
Yep you just put the little cap on the pins ( 1-2 i think ) for a few seconds, Hotflashing is when you boot your board with another 8RDA BIOS chip and then with it on you put back in the old BIOS so you can flashes the BIOS again by a floopy disc based BIOS update program.
If you turn the board on with the clearcmos jumper on the clear setting you can wave bye bye to your bios.
Hotflashing == teh risky business, but it will revive your board. Requires the following ingredients
1. Unsuspecting friend/associate with an 8RDA+
2. Putting their bios chip in your board
3. Starting your board
4. Pulling their bios out of your board while running
5. Putting your b0rk3d one back into yours
6. Flash
7. Wash, rinse, repeat as necessary
8. ......
9. Profit
Any one know if this place is good? Now that I think of it, I think I may have forgotten to move the jumper back once while I was testing it :( Damnit!!!!! Next time I work on this thing I'm doing it earlier in the day so I pay attention but I guess you live and learn. Schro, you say to find someone with a 8RDA+. Is that board and mine compatible, the only difference being what's integrated?
My bad, i thought i saw a + there.... its probably a 2 mbit bios, where the + is probably a 4mbit, so it won't work, you need an 8RDA bios.
Ya I figured they wouldn't be compatible. Anywho, when I got home from work Thursday I cleared the CMOS again and held the insert key when I turned it on and it worked like a charm. Thanks Schro for the tip!
