Just upgraded my rig yesterday and started having some probs.
AMD +3000 Venice
MSI Neo Plat 4
2 gig OCZ 4000ddr gamers ram
ATI 800 XL------------------------------------->Upgraded to the x1800xt 512
120 gig seagate drive
stock socket 939 fan----------------------->thermatake big typhoon
"Maddog surepower 400 watt PSU"
Symptoms
1.Computer locks up right at beginning "Microsoft Xp Screen" right after bios boots (faint image of he screen)
2. When it does finally boot after reset sometimes get a distorted screen, its frozen)
3. After i can get it fully booted i check the cpu temp( that Tt Big tephoons worjks great 32 c . but big Tt Big typhoon drops from 1300 rpm to 700 rpms. ?
4. o try to overclock (from 1.8 to 2.0) using the bios or the MSI cell it makes a strange noise then locks up.
it has always OC to that speed before the upgrade.
Future down the line i will try to add a crossfireboard and another 1800xt.
you think it might be the shitty 400w maddog?
thinking about these PSU
XCLIO 450w
http://www.newegg.com/Product/Product.asp?Item=N82E16817189003
XCLIO 480w
http://www.newegg.com/Product/Product.asp?Item=N82E16817189004
or a sunbeam
http://www.newegg.com/Product/Product.asp?Item=N82E16817709004
any recommendations as to others?
trying to stay under 80 bucks and that the wife says i pushing it
thanks guys
AMD +3000 Venice
MSI Neo Plat 4
Symptoms
XCLIO 450w
XCLIO 480w
or a sunbeam
thanks guys
