Save $$$$ but take your own risk!
My friend give me the folllowing info for upgrade 9800SE to 9800PRO!!
Power Color (~only) RADEON 9800SE 128MB video card model ( R98SE-C3 ) was based entirely on the RADEON 9800 PRO ( XF98-C3L ) design, there is NO difference betweeen the chipset , memory , resistors, the pin out, etc are identical except that the pipelines as below
Radeon 9800PRO 8 pixel pipelines
Radeon 9800SE 4 pixel pipelines
The RADEON 9800SE video card it can be unlock from 4 pipelines to 8 pipelines as follow
The step to change the 4 pixel pipelines to 8 pixel pipelines for Radeon 9800 SE r98xe-c3 (128MB 256 bits)?
1) Download the Omega drivers 2.5.22 from omega homepage http://www.omegacorner.com/index_ati.html
2) When you start install the driver, you should pick the option "Soft-Mod 9800SE Omega Driver 9800SE -> 9800 NP/Pro/XT".
3) Actually, it is already unlock the other 4 pipelines when the driver finish installed. However, you cannot really tell from video properties. You should download riva tuner software http://download.guru3d.com/rivatuner/
4) After installed the riva tuner, you can see the 4 pipelines are already unlocked. (You need to responsible for your own risk!)
3DMark 03.
9800 Pro has 5401 points.
9800 SE (4 pipelines) has 3626 points.
After unlocked 9800 SE (8 pipelines) has 5151 points.
If you are successfully unlocked it, you will see the picture as below:
http://www.philippi.com/temp/picture-1.jpg
I heard that Power Color is the only manufacturer who has this special 9800SE video card. But some other guys said Sapphire one is working too....
Good luck pal!
3DMark 03.
Good luck pal!
