D
Deleted member 134350
Guest
I started my 24hr leak test last night at 10pm Est. The hardware for my Maze4GPU block for my x1300pro pcie 256mb card wasn't right; they sent me a two allthread setup that was the wrong size. Not only was it too small, I needed the 6-32 rods and I needed all the hardware for four posts. So I had to cut the heads off of some 6-32 machine bolts and rig up something until my replacement stuff comes in. I didn't want to hold up the build any longer.
I ended up buying an Ultraproducts Aluminus tower case, the construction is excellent and the layout worked out great for water cooling. I really like the way the front cover is on metal removable hinges. I will take some pictures as soon as the leak test is over and I put the computer back together.
I want to thank all the people that helped this rookie venture into the world of water cooling. Since this is my first build I know some of the things that I did could have been done better, next time.
