I Really Need Help With This!!
Ok guys,
This is really a problem and I NEED immediate assistance. Whenever I go to print something, the print window comes up and then freezes. The box and IE window stop responding and I have to Ctrl Alt delete. This happens just about every time I go to print something. Once in awhile it will work but usually it doesnt. This same thing also happens when I go to browse for an attachment to attach to an email. This REALLY is driving me to the point of throwing the whole computer out the window since I am totally unable to do what I mainly use the computer for. I am running Vista Home Premium. PLEASE HELP!:(
have you turned on the printer?
just kidding :D,
first make sure that your printer supports Vista and that you have Vista WQHL drivers for your printer. Then make sure that there is only your printer listed as default, there could be a conflict with the drivers. your printer uses LPT1 or USB ?
If everything "seems" normal, then u might want to reinstall windows from scratch
Thanks for the reply!
Yes the printer is on:p But yes I do have the Vista WQHL drivers. And yes its the only printer, listed. The printer is on USB. The fact that I am having teh same problem with attachements makes me think it is an OS issue. I really dont feel like reinstalling windows but if I have to, what is the best way of getting all my applications like word, powerpoint, etc and files onto the clean install?
so all your USB devices have similar problems? have u installed your Mobo drivers correctly?
if u want to reinstall Vista, first you have to backup your data, burn it onto a CD or use a memory stick
How did you install your printer drivers?
What does your printer manufacture say?
The other usb devices work fine. I am thinking that it is a problem with either Internet Explorer or the OS. It comes up when I browse for files to attach to a document in my email program as well. I dont know what the deal is.
Edit: all those features work fine in firefox but not in IE. I have had trouble with IE before and I never was able to find a way to fix it. What can I do?
You would reinstall them, the same way you did before to get them on your computer.
Printer could be getting disconnected by Vista. You can try to run the following command into an administrative prompt:
NET USE PRINTERPORT \\COMPUTER\PRINTER /PERSISTENT:yes
Sounds to me more like there is some kind of folder / network resource in your Explorer that is inaccessable or turned off so when you go to browse it locks up because it is trying to find out what is available.
So go into My Computer and make sure everything in there works including mapped drives, make sure your CD-ROM's are clear.
By any chance do you have an older version of MS Office installed? (2000,XP)
Also, what is the make and model of the printer?
If it is a Lexmark or if you have ever previously had a Lexmark hooked up to that machine then there may be something in there that is causing the problem.
All folders are working. I have MS Office 2003 Professional. It is an HP psc217. I did use to have a Lexmark but it is uninstalled. Also as I said, everything works fine in Firefox so it makes me think it is a problem with IE.
