I ran HD tach.....
r1fl3m4n
And my 250GB WD HDD gets only about 11.5 MB/s burst and 11.0MB/s sequential.
That is absolutely horrible performance for drives on the SATA interface.... I was just wondering if this was a sign of HDD failure?
Sounds like a bad drive, so call up WD and see if you can get a replacement.
cable? drive? controller? try another cable and then another drive..
Ahh it was in PIO mode. Switched it to the SATA data rate and now it's fine. Thanks for the suggestions though.
