Well the I/O shield wont fit with the motherboard I have. Its the same one that cae with it. It sucks cause it fits fine on everything except the audio ports because the piece of metal is too wide between the middle of the audio ports. It isnt the bendable kind either so i cant just bend it and tear out.... Should I just clip the whole audio section so it can fit?
