I/O Panel Problem On The P6X58D
|Nexus|
There's a thin piece of metal bent at an angle over one of the ports on the back of the mobo. It's sort of disabling any possibility of installing the panel correctly to the back of the case. Most topics I've read about it say just to bend it flat, meaning it'll just slide under the panel (not the motherboard itself), and out the case. Is that what I'm supposed to do?
Annoyance can be seen at the bottom left of this pic:
http://www.brightsideofnews.com/Data/2009_10_23/Asus-P7P55D-E-Premium-Specs-Revealed/P6X58D-P-02.jpg
What do you guys think?
The panel won't align correctly with the ports because of that thin piece of metal sticking out of it. Look closely at the picture, you can see it slanted on an angle. What do you suggest I do about it?
