I/O Isnt working???
NoobToast
I just got this new Lian Li PC8NWX. Set everything up as usual, made sure everything was seated correctly, and powered it up. Fans turn on and everything looks good, but then there is a continuous beep that wont stop until i shut it down. The I/O pannel with all the USB's does not work, the keyboard or mouse plugs wont work and my Graphics card powers up, but wont display on the monitor. Probably a really easy explanation for all this, but i dont know what to do.
Specs are in my sig,
Thanks
Greg
From first guess -- and based on recent experiences -- there's a good chance that the motherboard is bad. However, that's only a guess.
Follow the steps listed in the troubleshooting sticky to confirm which parts are giving you trouble.
