I have 1gb corsair xms pc3200, a geforce fx 5900, and an audigy 2. Basically im looking for a new mother board and a new CPU, probably an AMD 400FSB cpu. Thanks in advance.
ok, had to ask what price range...
My suggestion go with an A64 and a via chipset motherboard.
If you want to go cheaper (tho you'll prolly be surprised at how low you can get A64 parts) you can go with an nforce 2 ultra 400 chipset and athlon XP - Do you want overclocked goodness or just power out of the box?
If you want overclocked goodness - go with a mobile 2500+
cheapness a 2500+ barton (which should easily overclock to 11x200 or 3200+ speeds)
power out the box - the highest speed you can afford...
