I need some input on a water cooling system..
bellevegasj
hydro system revision 1.03
Lian Li PC75
Aquaero LCD Control Panel
Danger Den 6800 Water Block
PolarFlo TT Loop Lock Chipset
PolarFlow TT CPU Chrome block
Eheim 1250 317 GPH (Possibly dual pumps)
Danger Den Dual (5 1/4) Bay Reservoir (Could I get by with something smaller or does anyone have a suggestion of something different?)
And 2 or 4 (depending on the setup) Pabst 120mm 4412 F/2M fans
I'm planning on getting either a Black Ice Pro 120mm Rad, but not sure if I need a Single or Double. Would this kind of setup need a dual radiator?
That pump is overkill for either of those setups. I'd go with a 1250 at the highest.
Also you don't need a NB block. A good heatsink, possibly including a small fan, will work just as well, without restricting your water loop.
That rad looks good, except that it only has 1/4'' fittings. A 3/8'' or 1/2'' system will give you better performance. The dangerden double heatercore is kinda ugly, but it should cool as well as the airplex. It's a little cheaper too.
I know the TDX block is good, I've heard good things about the cuplex as well. Personally I'd go with the TDX, just because I've had more experience with it, but it's up to you.
As far as tubing, cheap vinyl is usually fine (please don't flame me), but if you have any tight bends get some clearflex or tygon.
Hope this helps.
miro
Yeah, overkill on the pump, dude. NB block is a wais of time nergy and money. Go with 1/2 in tubing for performance and overclocking. Go with Danger Den. They've been in the business a long time and there stuff works well. Double heater core? Go for it. Ghetto is cool. You can get some primer and spray paint and paint it yourself.
Just remember you want to run both blocks in parallel. For example, radiator, y-spliter, cpu and gpu, y spliter, res, pump. That way each block is getting cool water.
check out www.procooling.com
I disagree about running blocks in parallel. The CPU won't raise the water temp by more than a couple degrees, not enough to significantly affect the gpu. And running in parallel means that each block only gets half the flow, which can really hurt your cooling performance. Especially with high-resistance blocks like the TDX.
miro
It really suprises me that you 2 would both say that the pump is overkill. Like I said, I'm new to this, but I would assume that the better the pump, the better the cooling. It might be better to go with a less powerful one just for noise sake... I want to be as quiet as possible without sacrificing any cooling power.
I agree, that pump is overkill.
I disagree about running your stuff in parralel. For some reason people seem to think that the second water hits the CPU block its temperature increases by massive amounts. This is not how it works. All water in the entire loop is the same temperature, an equilibrium is reached. Now if any of you want to dispute this with me ... don't ... it has already been proven in another thread by OMP and myself, go search :p
So running in parralel will not do anything substantial for the loop ... other then split the flowrate in half for each block (VERY BAD!!!). So if you're intent on doing parrelel setup, thats when you'd need a powerful pump like the 1260, but why pay more for a pump to make back some of that half loss of flowrate, for no advantages? Well its your choice heh.
Logically, that makes sense. But in actuality, an overpowered pump creates too much backflow and can actually hurt performance. Basically, there's too much resistance in a watercooling loop to force that much water through it. So it creates a sort of "traffic jam," where the water gets backed up and basically has no where to go. Which isn't good.
That's my understanding of it anyway. Anyone with a physics/hydrodymanics degree is more than welcome to explain it better.
For a TDX and 6800 block, the 1250 is a good bet. Another idea is the Liang 12v pump, aka Dangerden 12v pump, aka Swiftech MCP650. Other than that, look around for a pump in the 250-300gph range, with as much head as possible.
miro
What size reservoir do I need? Is there a too big or too small? I was going to get the Danger Den Dual (3 1/2) Floppy Bay Reservoir. Would that be good for my future setup?
T-Line all the way, screw res's!!! .. unless you make your own out of PVC Pipe, those are ok
1st I would suggest reading this article since there is some pretty good info in it.
2nd I agree with not getting the 1260 but would highly recomend the D4/mcp650 or the mcp600/AquaXtreme 50Z 12v pumps since they have about the same pressure as the 1260 and will put much less heat in the loop than any ac pump of similar pressure. If you want more performance just add a second one of those in series in your loop somewhere.
Personally I like using a res, it will clear the lines of air much quicker than the t-line but would get a dbl 3 1/2 as a min.
For the rad I would suggest not going with the Aqua-Computer since I believe it is a winding tube type and that will cause undo restriction in your setup. If you dont want to go the heatercore route I would suggest the BIX dbl or the ThermoChill HE120.2. If they are too big a single would work but to get decent temps would require a fairly strong fan (noisey)
As far as the water temps in the loop go it changes very little from coolest to warmest. It is not the same temps throughout tho, on a relatively highflo system like you are putting together (1 gpm+) the change depending on the heat load of you cpu and gpu would be in the area of 1°c to 2°c difference from the inlet to the outlet temps of the rad. The lower the florate the greater the difference will be.
As far as to which cpu block to get I would suggest you get one of these 3. TDX/RBX, D-Tek WhiteWater, or the Swiftech mcw6000/6002. They will each when setup right give temps within about 1°c of each other in your system.
For the GPU I would go with either the DD 6800 of the SilverProp Fusion HL since they have no mixed metals and would require little corrosion inhibitor in your coolant.
Actually the temperature IS the same everywhere in the loop. An equilibrium is reached, this concept is discussed in fair detail in another thread on this forum by myself and OMP (I don't feel like digging it up, go search for it). It seems to be a common misconception among people, but a thermodynamic system will reach a state of equilibrium.
Equilibrium does not mean that the temperature has to be the same all through the loop. Equilibirum means: energy in = energy out. If the temperature throughout the loop would be the same at all points that means that no energy is transfered period. Look at is this way - warm water goes into the radiator, cooler water comes out, indicating you have removed energy from the system at that spot. Reverse for the blocks.
In regards to the set-up discussion, from my measurements with the Eheim 1250 a parallel setup is dangerous. You need to make sure that your blocks have similar restrictions, otherwise most flow goes through one block and not the other. My loss of CPU block flow due to serial arrangement CPU/GPU blocks was only 10% compared to a parallel setup. But I don't have to worry about loosing flow on one site if one block gets fouled more then the other. Plus you save yourself a number of potential leak sites by not having the Y splitters.
Actually the word equilibrium refers to a number of situations. You're going to tell me that chemical equilibrium means energy in = energy out? Any chemist would balk at you for saying something as ignorant as that. As for temperature equilibrium, it has to do with the differential of temp. delta of an infentasimal interval of time t, when differentiated you will find that the temperature at any point in the loop at any given time is equal to that of any other point at that given time, you are considering the system on a macro scale, equilibrium refers primarily to the differentiaton of an integrated infentesimal variable in a system.
Interesting that you're mentioning the chemistry side here, what does a chemical equilibrium have to do with a cooling system? Unless of course you run a rather interesting system based on chemical reactions to transport heat - nothing. But I'd be equally happy to call the system at steady state if you prefer. And I'd say that a cooling cycle is a rather macroscale system from a quantum mechanical point of view, but be my guest trying to solve it analytically and prove that the temperature is equal throughout the system.
Let me give you some simple parameters I used to see what the temperature gradient in my system is:
CPU output 100 W, waterflow 2 gal/min, specific heat (water, 300 K) 4.179 kJ/kg K
Now, when I crunsh those numbers I end up with a delta T of 0.189 K over my CPU block to pick up those 100 W. While that is small, it's definitely not zero. And, since we assume that the system is at equilibrium, the same temperature difference has to prevail over the radiator (neglecting heat losses in the other parts of the system) to get rid of the energy you put in.
But I'm sure you'll be able to prove the contrary. I'm looking forward to it.
I believe he was using that as more of an example of how the word equilibrium can be used, not proving anything about water cooling. :p
have you performed multiple physical tests to prove this?
