I need some help on your guide...
I found this guide made by this web site. It's awesome! I love it! :) But, it really skimps out on details... Major details. Like:
In this picture (Found on page 2 of the walkthrough) it shows metal brackets with blue logo's. It was never mentioned in the guide. Is it important? If so where do I get it? What screws do I use?
"First, we installed the 120mm fan in the bottom of the case. While I am normally against using hot glue or the likes for mods, the fan fit snug enough that a bit of hot glue in each corner kept the fan securely in place and kept us from using unsightly screws that would have been visible from the outside of the unit...."
Don't I have to solder something? Or is there a hook up already in there?
"After we installed the control unit we routed the cooling lines out through the holes where the control knobs used to be. We used compression fittings here as well so that the cooling unit could be separated from the Xbox 360 at these fittings or by using the fittings on the back of the Xbox 360. Next we installed all the needed wiring for power and control of the pumps, and then we wired the AC adapter to the control unit. Using garden variety wire nuts we spliced the AC adapter to the original power cord left over from the ceramic heater."
This paragraph needs work lol! Major work...
1)How exactly do you install the control unit?
2)How exactly do you install "the needed wiring for power and control of the pumps"??
3)How exactly do wire the AC adapter to the control unit???
4)Where do I get these "garden variety wire nuts"????
In this picture (found at page 3 in the walkthrough) what are those metal rod's for? It wasn't mentioned in the walkthrough as far as I know.
Also, Throughout the walkthrough they never tell me when, or how to put the coolant in. Or witch type of coolant to use.
I mean do the line's have to be filled with coolant along with the tank? Or can I leave air in the lines? :(
BTW, What do you think about this as a cooling unit for my 360?
-Thanks!
A) In this picture (Found on page 2 of the walkthrough) it shows metal brackets with blue logo's. It was never mentioned in the guide. Is it important? If so where do I get it? What screws do I use?
B) Don't I have to solder something? Or is there a hook up already in there?
C) In this picture (found at page 3 in the walkthrough) what are those metal rod's for? It wasn't mentioned in the walkthrough as far as I know.
D) Also, Throughout the walkthrough they never tell me when, or how to put the coolant in. Or witch type of coolant to use.
FYI, I'm just a member of this forum. I don't do watercooling, nor do I have a 360. But, to answer some of your questions... or just to give you some form of help (if any of this is helpful, lol)... here goes...
A) Those are the waterblocks. AFAIK, they come with the Koolance WC kit.
B) The fan is part of the kit. It has a connector.
1 - 3) While I understand you're looking for a step by step guide, all I can say is: Find a way to make it work.
4) Hardware store.
C) Again, they're part of the Koolance kit, I believe. They're for connecting the tubes from the radiator to the 360.
D) Lookup a general guide for watercooling. Check the Overclocking and Cooling subforum.
