i need some help from x800 pro
athan818
So wried
i have this X800 pro running fine on my P4 system.
P4 3.0C
i can even bench mark anything
however, i installed this card to my giga-byte 754 A64 3000 system,
i started to do the fresh install for this new system, dos mode, i have no problem at all
once the hd finished formatting and loaded all the files to the HD, guess what?
when window installation screen pop up, display start shaking
any idea ?
it cant be power supply coz they are identical.
it cant be my mobo, coz it ran fine with 9800 aiw
any idea please?
thanksssssssssssssssssss!
with 9800 aiw
i never had problem with it
with P4
i did not have problem with it but i was not using lcd
athan818 said:
So wried
P4 3.0C
any idea ?
any idea please?
if its an LCD display make sure your running at its native resolution.
