WintersFury
- May 19, 2007
Ok, I'm currently looking at 3 cases.
The Lain Li PC-60BPLUS2 which has the 120mm fans in it which I like (Though is having that much in positive air flow good as it only has 2 80mm exhaust fans).
The Lain Li PC-65B which is a bit less expensive and has a more balanced airflow and is a few bucks cheaper.
And the Sigma Unicorn which has a ummm... Interesting? name and good looks. However I can't find more pics anywhere to get a better look at the setup of the fans and internals. Not even on their website, so if anyone knows where I could get a few more pics, that would be great!
I'm looking to transfer my setup with an OCed Quad into it. Not sure if it'll be a 6600 or 9300, but one of those two so it needs decent air movement to keep things cool. I'm leaning more twards the Lian Li cases due to knowing exactly what to expect from the pics and all, so suggestions between those two espcially would be nice unless you know more about the Sigma case then the little Newegg has to offer.
Thanks!
::EDIT:: Found some more pics of the Sigma case on Newegg, they have a whole bunch for the one with the PSU included that they don't for the one without it. You can see them here for anyone interested.
Thanks!
