I need some cooling advice...
Lyquist
OK, here is my situation. My CPU is running at 67C with the case off while running Prime95. It runs about 71C with the case on. I need someone to recommend a cooling solution. I don't want to buy a new case, but I am willing to buy a new heatsink and fan combination (I am using the retail fan that came with it). Here are my system specs...
AMD Barton 2600+ running at 2.3GHz 2Volts
512MB DDR
MSI-KT6V motherboard
etc...
Thanks in advance for your help. I am thinking about buying a si-97 and a 92mm fan, but I don't want a loud fan and I don't know which one to get. I also don't know if the si-97 will work on my board. Will I have to take the motherboard out to mount it??
Lyquist
The SI-97 is a great choice. I checked thermalright's compatibility list and your motherboard is in the clear. As for the fan, I would reccommend this one http://www.svc.com/pahywabefb.html
it is currently out of stock right now but it is normally about $6 and its a great fan.
I have never installed this heatsink so I can't give you any tips but I did look up a few reviews and saw that it does not require you to remove your motherboard to install but it can be slightly difficult to install.
still looking for some advice...preferably from someone who owns a si-97. Thanks.
Lyquist
I am using the V7 andmy AMD 2500 is at 27c
and the fan Specification:
Compatibility: AMD 462 Athlon XP 3400+ & Intel 370 PIII
Dimensions: Fan: 70 x 70 x 25 mm
Bearing Type: 2 Ball Bearing
Nominal Speed(RPM): 3000/ 4800/ 6000
Max Air Flow:(CFM): 49.0
Heat Sink Material: Copper
Rated Voltage: 12V DC
Connector: 3 Pin
Noise(dBA): 24/ 35/ 47
Special Features: Tiny fin technology and all Copper Material
Model#: VOLCANO 7+
Item#: N82E16835106014
Rating: Vote(s): 135 Review(s): 74
Free FedEx Saver Shipping
Is it loud? NO but Vantec is and it is a good heat sink to
Vantec AeroFlow VP4-C7040 For Intel P4 478 -RETAIL
Specification:
Compatibility: Socket 478
Dimensions: 74.5 x 87.5 x 60 mm
Bearing Type: TMD (Tip-Magnetic Driving)
Nominal Speed(RPM): 5600
Max Air Flow:(CFM): 35.5
Heat Sink Material: Aluminum/ Copper
Noise(dBA): 38
Special Features: Copper Core for superior heat dissipation.
Model#: VP4-C7040
Item#: N82E16835110008
Rating: Vote(s): 96 Review(s): 74
FedEx Saver Shipping $4.99
2v running through your chip?? No wonder it's so damned hot. Can't run it any lower?
The Volcano 7 and the Aeroflow units ARE loud. They are not near as efficient as a Swiftech or Thermalright copper heatsink with a decent 92mm fan mounted on it. Not to mention it will dissipate heat around the outside of your CPU socket as well.
liquid cooling wouldnt be a bad idea. 71c is way, way too hot.
how many case fans do you have?
I've got the case off right now and it's running about 67C. It idles around 45C. That is a huge increase. It is showing me that this stock heatsink/fan just can't do the job. What do you guys think? And water cooling is not an option at this point.
Lyquist
Nothing is wrong with getting a si-97. I just don't know which 92mm fan to get for it. Can someone suggest one? I don't want a loud fan.
Lyquist
Lyquist said:
yea i know, i stated that in my first post if you would have bothered to read it. You can do some quick searching and see that other places carry that fan too...
http://www.frozencpu.com/fan-83.html
http://www.casecooler.com/panaflow92mm.html
http://www.sidewindercomputers.com/pa92mesp.html
http://www.coolerguys.com/92panaflo.html
and btw, that Zalman fan does not push that much air
Stiffy, thanks for all your help. However, the fan has to come from Newegg (it's a long story). Would you be able to recommend one from Newegg that is better than the Zalman that I linked to? Thanks in advance for your help, I appreciate it.
Lyquist
