I need more RAM.
Elf
I've been playing BF2 and I've come to realize that I need more RAM. Right now I have to sticks of 256 or something to make 512 I guess.
Should I buy 2 sticks of 512 to make it 1.5 or just take out the old ones and just make it 1?
Should I stay with the same brand I have? Corsair?
check your mobo manual make sure you can fill up all dimms..........1.5 gigs would be great, but 1 will be good too, and yes stick with same brand if you can
soulsaver_8229
Elf said:
I lost my manual..... :(
Google your motherboard model (it is usually printed on the board itself) and the manual can easily be found as a PDF document.
I would highly suggest 1.5 GB for BF2, as 1 GB isn't quite as smooth. The extra ram also reduces load times.
Well I find the manual but its all written in gibberish.
Example:
íŒÁ/?ÛUXë?žBYÅI?v+Ô7Žmn?b?ÁRtàwösªyñ?;?c??Ѻ?KQsÚQ?ðl???~Ì?XNkRÌ{?nHlrÌèÉ?6ž?ütlóÞ?ØipB??Ž~??LE?|
b@ÑjÕð6è?0??Û
À?E{Ø~ÊïSá%ƒzøóÁ;?D??5a???s{x åOi)m??
Ð?ke
_<ã?G?$՚DéÔ?vorÿ6ô.7q?$`MXµ6 à
-?^žÓø?î?$Òu}wÍæÞKjÉ?ùïÄy?Zú???É.+Ô?e??6???ÒP(êÕÌÙoqðRšÒÒ"G)?0!?W?Û?A<r?mý?GuNA(eòö?ÛÖ?ÓnŽzÕZ>È1ÎC?ƒ]œÕ?ՃŒ?v?_![?sTfH*ñÁmÇüÖj????1.?~ål?ôT9KË?R?z;Ó,NËZøcfú*žV?É?͟úÿ+
ea1R<ºÝ?ï?8?AáúQð?>ô?YÆÝüÙ%æaû}UGêÍ Õ??c~º?LÚ,?Ä?ÜwÐ?#šXe
?Žê??fu.?tÌÀ?ÐD2Ð26??6??aù_ïŽ/â%Ë?vË^l??MŽ|lÌk?*ò Í???Nö{?%Œ&HÂ86nM??ìõ73?º:?ž_?5??L:
My mobo is an Asus P4C800-E......
Eek! :eek:
It says "You may install 64MB, 128MB, 256MB, 512MB and 1G DDR DIMMs into the DIMM sockets using the memory configurations in this section."
Does that mean I can only have a maximum of 1GB of memoy?
Elf said:
Eek! :eek:
No. It means the largest single size dimm that you may use is 1GB. You don't really need to worry, though, as I have not seen any 2 GB DIMMs on the market (not that they do not exist).
Somewhere it should tell you your maximum memory altogether. Usually it is 2-3 GB.
ya that sounds like good ram, several of my friends have Corsair and have have had no problems with it, I would stick with that
Excellent ram right there. I actually brought that ram about a month ago for BF2 to make 1.5 gigs of ram. Do not regret that decision.
But damn, that price is 10 dollars more than what I payed for it!!!!
