I need midrange PC buying advice please
Status
Not open for further replies.
Lazarey
I have needed a new computer for a long time, as my current computer is a budget Dell Dimension 2100 from year 2001.
My grandparents decided that I needed a new PC and have offered to buy it for me.
I've already had a few days to do research but I just found these forums and the people here seem to be very knowledgable. I need to make a decision by tonight or tomorrow at the latest because they always think you are not interested if you don't act quickly on something they offer you.
They don't know ANYTHING about computers, so they don't understand the amount of reasearch that one should put into such a purchase.
The price range is around $1200. I'd like to keep it around $1000-$1100 if the system doesn't include a monitor and then purchase a quality monitor for around $200-$300 on newegg or something.
One requirement I have for the computer is for it to very upgradable because I will probably not have enough money to by another PC for several more years, so I would like to be able to upgrade/add components if I need to.
From things I've read it seems like the Intel Core 2 Duo processors are superior to AMD's X2, so I think I would like to have one in whatever PC I choose. Any thoughts on that?
I would also like to know what operating system I should get.
I'm planning on using the computer for internet surfing, storing digital photos, ect. I am getting into digital photography more, so I might be doing some image editing eventually.
I am currently leaning towards Velocity Micro as I have heard some bad things about the big companies (HP, Gateway, Dell, ect.) lately and VM seems to have a lot of satisfied customers. But my Dell has lasted me a long time so they are still in the back of my mind as far as buying a new computer goes. Also I have a friend who said that he just got Dell certified to work on their computers without voiding the warrenty or something like that, I didn't get a chance to ask him more about it.
I would really appreciate anyone's help with my situation!
I hate to double post but I would really like to get some advice quickly.
I'm done a lot of research and I am really just wanting some opinions on different PC makers. Like I said, I'm leaning towards Velocity Micro at this point.
Go ahead with VM if you'd rather not build it yourself. I think you could save alot by building it yourself, but if you don't have time/patience/will to do so, then VM is probably the best choice out there (but they seem to be over your budget). If you need help with which parts to choose, just ask. For starters, go with an E6300, P965Express chipset board, 2GB of DDR2-800, and a 7600GT (if you game casually on resolutions smaller than 1024x768) or a 7900GS (if you game at higher resolutions). Your monitor budget sounds like a 20" wide, so a 7900GS would be fine, but if you can, get the 8800GTS.
Thanks for replying!
As far as VM being out of my price range, I was thinking of getting the Vector GX Holiday Edition
http://velocitymicro.com/wizard.php?iid=86
it seems to be a pretty good choice but I would like to know what kind of expandablity/upgradablity it has. I also don't like that it only has a 90 day parts and labor warranty and 90 day regular buisness hours support.
You can upgrade the CPU to a Core2Quad; you can upgrade the video card to anything for a while (pci-express will be around for a while); you can upgrade the ram, too (ddr3 wont be out until 2008, I believe); drives are always upgradable, but keep in mind the new intel chipsets only support 1 IDE controller, so you can only have 2 IDE devices unless you add a PCI IDE Controller or use sata converters. I think the only thing bad about that rig is the intel board, 'cuz you wont be able to OC with it. Too bad your only choices for vidcards are 7600GS'... the 7900GS would be better for the monitor you want, or even the 7600GT.
If I had $1200, I'd get this:
$309 - Intel Core 2 Duo E6600 Conroe 2.4GHz
$135 - Gigabyte GA-965P-DS3 Socket T (LGA 775) Intel P965 Express
$210 - G.SKILL 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
$130 - XFX GeForce 7900GS 256MB DDR3 450Mhz ($190 - $20GCO - $40MIR)
$120 - Corsair CMPSU-520HX ATX12V v2.2 and EPS12V 2.91 520W
$40 - Cooler Master Centurion 534 RC-534-KKN2-GP ($50 - $10MIR)
$80 - Seagate Barracuda 7200.10 ST3250620AS 250GB 7200RPM SATA300 16MB Cache
$36 - LITE-ON 16X DVD±R DVD Burner W/ LightScribe Black SHM-165H6S
$1060 + tax and shipping
Most parts have at least a 3yr warranty. The vidcard and ram have lifetime warranties. The CPU and mobo have 3yr warranties. The PSU and HDD have 5yr warranties. The optical drive and case have 1 yr warranties.
I hate to ask because I'm sure it's something I should know, but what's an IDE Controller and IDE Devices?
I appreciate you typing out that list, but there is no operating system on there. If those parts add up to $1060, then after I spend $200 on XP Home I would be over my limit because I wouldn't have any money left for a monitor.
$200?!? go with OEM:
$90 - Microsoft Windows XP Home Sp2b 1pk w/Upgrade Coupon for Vista
Its too bad you missed the XP Home Sale at Office Depot for $100 - $70MIR. The deal comes around every now and then, so you can keep an eye out for it if you want to wait for it. You could also get XP 64 edition instead, for even less:
http://www.surpluscomputers.com/store/main.aspx?p=ItemDetail&item=SWW13455
IDE (or EIDE)...
http://en.wikipedia.org/wiki/Enhanced_IDE
E6600, 2GB DDR2, 7900GS... that config would be way over your budget at VM. Build it yourself and get a better computer. Have your friend help you, if he/she has time.
Well, thank you for all your help! I have decided to go with Velocity Micro. I know I could get a better computer for the money if I built it but I think my grandparents would understand better if I bought it. Since they are paying for most of it, I'd like to make them happy.
Thanks again for the advice!
ChrisMorley Prod. Dev. for Velocity Micro
ChrisMorley is the Velocity Micro Rep on this forum. You might wanna send him a message if you have questions or anything.
Status
