i need help
Bladerz
i get this error i believe its on sound, but im not sure, its the blue screen of death
Stop: 0x0000008E (0xC0000090, 0xF76EC4F6, 0xB80DF254, 0x00000000)
senfilt.sys- Address F76EC4F6 base at F76AA000, Datestamp 414a45cc
iget it when i try to run a game.
Run adaware and check for spyware because that is a frequently abused file.
If your system is clean then I would suggest updating your soundcard's drivers.
I dug this up from google:
The process Creative WDM Audio Driver or Sensaura WDM 3D Audio Driver belongs to the software unknown by Creative Technology Ltd (www.creative.com) or Sensaura (www.sensaura.com).
Description: File senfilt.sys is located in the folder C:\Windows\System32\drivers. Known file sizes on Windows XP are 381056 bytes (50% of all occurrence), 732928 bytes.
The driver can be started or stopped from Services in the Control Panel or by other programs. There is no file information. The program has no visible window. There is no detailed description of this service. File senfilt.sys is not a Windows core file. Therefore the technical security rating is 5% dangerous, however also read the users reviews.
Important: Some malware can camouflage themselves as senfilt.sys, particularly if they are located in c:\windows or c:\windows\system32 folder. Thus check the senfilt.sys process on your pc whether it is pest.
source: http://www.file.net/process/senfilt.sys.html
