I Need Help
ademster
My Wifes computer Jetway Mini Q 265Twin, Well her power supply died with in waranty, but they say it isnt covered... Well the power supply is a funky lttle thing... It is a Seventeam, ST-231MZ model its 230Max Watt...
I need to find one just like it same brand or not... the Seventeam reps wont reply to my messages... if anyof you know where and how I can get a new psu for this thing I would appreciate it... thanks
Adam
If its standard ATX form, you should be able to replace it with a Fortron, Seasonic, etc.
It came out of my wifes Jetway MINI-Q 765 TWIN
I dont know what type it is... damn company that makes it doesnt have it listed on their webpage ( seventeam ) and Jetway doesnt list it either....
Dimensions of the PSU and the ATX connector pin count would help(20 or 24 pin)
