I need help with purchasing a motherboard!
TheBear
fried my motherboard a week ago and luckily nothing else was damaged. I has an ABit nf7-s with a amd xp barton 2500. The cpu still works but now i am wondering should i get the same motherboard or get a better one. I dont want to overspend so i need to know what are the best options?
Best bet is probably just to get an A7N8X-E Asus board. Most Athlon XP mobos havent been changed in a long time and are being fazed out so they should be quite cheap.
IMO the NF7-S is one of the better Socket A ones, so if you did like it getting another one won't exactly be terrible. But FunkStar's suggestion of the ASUS board a good one. Heard the DFI Lanparty Socket A board is real nice, and a super overclocker.
I am not terribly interested in overclocking. However, doesn't the asus one have better sound? the price is the same. which one is better? i will just pick one of those.
Haven't looked up the newest version of the ASUS A7N8X, but if it's like the older ones, both it and the Abit NF7-S have NVidia's Soundstorm for sound in the chipset.
also i was wondering is there a way to check if my cpu is properly working? also will my motherboard mess up if my cpu is dead? I am 90 percent sure its okay but there is a slight chance that its messed up?
I think i am going to get the abit nf-7. i dont see anything that is signifcantly different than the ASUS A7n8x. unless i am missing something.
Back when me an my dad were both using Socket A CPU's I had the NF7-S, my dad the ASUS A7N8X Deluxe. Only major difference was the BIOS screen, ASUS does tend to use a different BIOS menu then a lot of other boards. Not harder to use IMO, just different. And the ASUS had a unique post code error reporter, one could enable it to actually say spoken word errors if it had an error during posting...imagine a nasal female voice saying stuff like "SYSTEM FAIL DUE TO CPU OVERCLOCKING" as an example, assuming you really did do too agressive of an overclock and it had a reason to warn you. Otherwise...no, they are pretty close to the same.
That sounds pretty cool. Its only a 6 dollar difference so whatever. Dont wanna waste time thinking about it.
Yeah it is...but I've had ASUS boards, and after a while I disable the voice, even if it only comes up on an error. Got on my nerves. That and at least by reputation, the Abit NF7-S is a bit better overclocker.
Okay i am going to go ahead and purchase the abit nf7-s.
One more thing though, I got my motherboard tested at buy and he said my memry slots fried. However, When i start up my mobo without any memory i get one long beep which means memory problem. However, when i install the memory no beeps come up. which i guess means its dead. But wouldnt there be no beeps for the memory if my memory slot died?
