Sobek said:I just realised you live in Greensboro along with fat_boy.
Dillusion said:get all your lian li cases at excaliberpc.com .... PC65 series for 90$ + 8 for shipping, its unreal , best place, ive ordered 2 from them so far
Dillusion said:nope, thats it, only a window, but for the extra 10$, its worth it to have a window
Sobek said:Thanks, but I plan on cutting my own window for the wormhole portion of an active Stargate for my Stargate Mod theme case. I already have a ton of ideas and am beginning to sketch them out as well as researching WC parts. I'll start the work log in a few weeks once I have everything so keep your eyes on the lookout for it.
wtburnette said:Make sure you post pics when you finish your case. I'm a huge Stargate fan and I'm very interested in seeing your results!
Pagan Wizard said:Why wait till he's done with it........post a work log so we can see the progress from start to finish.
Chrisman5000 said:First of all, make sure to sleeve them; this makes your life so much easier. Then just start tucking! I dremeled out the side of the 5.25 bay and ran wires down the right side of the case. It makes things alot easier to gut the case, never try and hide cables after all your hardware is installed. Take everything out, hide/route every single wire according to where you think you will need it and then install your stuff and continue to hide the remaining junk.
If you use SATA drives make sure to buy long cables and actually route them behind the mb between it and the tray and then up to your drives for an invisible look. Twist ties are also your friend.
If you look closely you can see a black velcro strip on the side which is hidden when the windowed side panel is on. There is also a little hole next to the velcro strip, I stick my cold cathode inverter on the velcro strip and run the small power wire through the hole and behind the chassy and out of view to an available molex connector.
