i need help with mobo memory settings on A8N
I have an A8n and i have two sticks of this memory right here
http://www.monarchcomputer.com/Merc..._Code=140326&Category_Code=Unbuffered_Corsair
Now the latency it says can be run at 2.5-3-3-6. But i just have it set on auto right now, which i assume it's running very loosely and not very low on those settings. My question is do i go in the bios and try to adjust it to make it run faster, or do i leave it alone because everything is running so smoothly?
thanks
Eric
you can play with it all day long if you want, without doing any damage.... but when you select a setting that doesn't work you will need to reset the cmos to be able to boot (or the settings will be automatically moved back to default...can't remember at the moment.)
You may want to DL a program to find out what your current RAM timings are (http://cpu.rightmark.org/download.shtml has a good one called RMMA 3.46 - will need a RAR extracter to unzip). You may find that the board is already running the timings that you posted above or at least you will see the timings being used so you know what is already working.
You run Memtest, which boots from a floppy or CD.
If your timings are too tight, you'll get errors, then you can reboot and set them back.
2336 is fine and safe. Some can even run at 2225 at 200mz. If you try to OC to high levels, you'll need to run at 2.5, 3, 3, 7.
G.Skill LE memory is rated to run at 2225 at 200mz, and 2.5, 3, 3, 7 at 300mz.
Others relax that last number, and run at 2, 5, 5, 10 or something like that.
It's really trial and error.
