I need help, please
So I have a little bit of Christmas Ca$h and wanting to build a cheap gaming PC as my current PC is ancient. I had a few questions below.
Current specs:
AMD Athlon 3700+ 2.2GHz
A8N SLI DELUXE with A8N PREMIUM BIOS v1303
4GB DDR
Nvidia Geforce 8800GT
650W PSU
2TB Hard Drive
Cheap Gaming PC Build:
AMD A6-5400K Trinity Dual-Core 3.6 GHz $40
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113282
ASRock FM2A68M-DG3+ $46
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157578
Klevv Fit 8GB (2 x 4GB) 240-Pin DDR3 $30
http://www.newegg.com/Product/Product.aspx?Item=N82E16820101078
Total =$116
Left $84
The A6-5400k APU is comparable to the 8800GT, but I found a GTX 570 for $60 which is a substantial upgrade. Though It would also be nice to go with a SSD which I don't have also. I guess I could just get one later. So I think I'll jsut go with the video card. Any thoughts?
My general advice, applying to everything in life: Don't patch up, in the end it costs you more; save, work, save some more, do it right.
If you have to do it now, a better GPU will be preferable to a faster hard drive, 100%, but that's in theory. If the games you play/wish to can be run by the APU, then obviously the opposite stands.
It's too tight a budget, but in the end, you know best.
Agreed. Save your money. The effect of the upgrade you're looking at will be minimal.
Believe it or not, an SSD would probably make a more noticeable difference than your planned upgrade.
If you reuse the case and PSU (and run a non activated copy of windows 10)
You might be able to scrape by with a budget of $240-$300 and get a 2200G, b350/a320 mATX, 2x4 ddr4 kit.
$90 2200G
$60 AM4 a320/b350 motherboard
$80 2x4gb ddr4
It will help if you can buy used, open box, or items on sale.
A nearby microcenter would help greatly. They even have some cheap $30 120gb ssds if you are trying to cut a close budget.
It isn't the most glorious, but it is mildly doable.
I'd agree that a 2200G would be the best bang for buck and HUGE improvement over your current setup. Even the integrated Vega 8 graphics unit is significantly more powerful than an old 8800GT. I'd highly recommend a small SSD (120-128GB ish for $30-40) to give you hugely improved startup and load times though.
