I need Freesync display for Xbox One X and Nvidia GPU
HisSvt76
Looking for a not too expensive 1080P Freesync display that will work with Xbox One X and my GTX 1060Ti GPU.
Been looking and a little confused I know the Xbox needs Freesync thru HDMI and the GPU Need it thru Display port so the monitor has to do both. Not looking to spend a ton size between 22-24 inch display.
Any help would be greatly appreciated.
Does that have freesync on hdmi though? Doesnt look like it
It was hard to find, but you're right. There is a single line on a single page in the manual that says DP only.
That would make the cheapest option the AOC G2590FX. AOC quality isn't the greatest, though.
https://www.amazon.com/AOC-G2590FX-Framless-1920x1080-DisplayPort/dp/B07D377Q6D
Next best option is the Dell S2419HGF. It has issues with its pixel overdrive, though, which means no 1ms response time without bad visual artifacts.
https://www.amazon.com/Dell-Gaming-Monitor-response-FreeSync/dp/B07MB7WT39
Both are $230, but if you have Prime the Dell is the cheapest right now at $150 while the AOC is $200.
