kevineugenius
- Dec 9, 2006
Currently I'm running 2x 1gb 6870s at 3600x1200 and they just don't cut it. I'd *like* to not go dual-card, but I'm on a low budget. My current plan is to double up on GTX 480s because I can get used ones for reasonable prices. After a PSU upgrade and two of those, though, I'll probably be just under $350 and getting "old" tech. Would I be better off with like a 7950 or some other newish card in the $300-350 range?
