I need an SFX PSU
I was looking at that one, but the depth will interfere in this setup :( I found that Enermax has a sweet 320 watt (model EG320S-VB) with 24A on the 12v, but I can't find one in stock. There is also a modular by Ultra, but, well.......
You're in luck, I just so happen to have a pretty new one in my FS thread :D:
http://www.hardforum.com/showthread.php?t=1430760
Depending on what hardware you're planning on running with this psu, the Enermax may not be enough. I was able to run an X2 3800+ Windsor at 2.8Ghz with an 8600GT, but when I upgraded to an 8800GS it was too much. If you're running an 8600GT or less, the Enermax should be fine, otherwise, the 300W Seasonic may be a better choice.
