I need an inexpensive barebones rig
Charger69
Hi, as previously posted, I'm having troubles with my dinosaur PC. After some thought upon the subject, I got into the idea of spending some dough and just upgrading the 5 year old machine.
My machine is as follows:
AMD Athlon 2100+ XP
Soyo Dragon Platinum mobo
768MB DDR400
EVGA 7800 GS AGP
I don't want to spend too much money, I'm thinking my budget right now is in the > $500 range.
I need a good mobo and processor. I don't know anything about today's processors, so I am kind of lost in the almost limitless options it seems and no idea what speed is anymore because pipe length makes the performance different. :confused: I read some good things about Opterons...?
The mobo must support AGP. I was thinking one of those boards with an AGP and PCI-e but I know they can be costly. If possible I'd like to get more RAM. Right now my rig has a stick of 256 and 512, DDR400. So I'm thinking the budget may need to flex some to get some better ram than what I have, otherwise I won't be making much of an upgrade of my old system. Also, I'd like it to be overclock worthy, to some extent.
My rig used to be a good OC'er, when it wasn't obsolete... :)
Any takers?
Thanks,
Charger69
I always did like a challenge. :)
Well the absolute minimum you need is this:
Intel Core 2 Duo E4300 - $179.00
ASRock 775Dual-VSTA Socket T Motherboard - $57.99
Total: $236.99
The mobo supports both PCI-E and AGP. However, PCI-E will take, I think, a 10% hit in performance. From the reviews on newegg, the mobo looks like an OK overclocker. The E4300's 9x multiplier makes it a lot easier to overclock. You can easily hit 3.0Ghz.
$500 for what? just mobo/cpu/ram? or gpu/hdd/dvdrw/case/psu too? Core2Duos are the thing right now, since they'll give you the most performance for your money.
First off, you'll need danny's suggestions... with that board, you can re-use your ram, but from the sounds of things, you want more. Therefore, you should add this:
$100 - G.Skill 1GB (2x512MB) DDR2-800 F2-6400CL5D-1GBNQ
or this:
$185 - G.Skill 2GB (2x1GB) DDR2-800 F2-6400CL5D-2GBNQ
The board can reach a reported 300Mhz FSB, so you probably won't hit 3Ghz, but 2.7Ghz is still a nice boost from 1.8Ghz. Here's some reading material for you:
http://anandtech.com/cpuchipsets/showdoc.aspx?i=2903
http://www.anandtech.com/mb/showdoc.aspx?i=2810
http://www.anandtech.com/showdoc.aspx?i=2813
http://www.anandtech.com/showdoc.aspx?i=2814
Summary: The board is a good, budget stopgap solution for people who want to get more life out of their DDR and AGP stuff. DDR400 is still fine for today's applications, and only high end graphics cards will be affected by the 4x speed of the 16x sized pci-e slot, but not by much (10% hit, like danny mentioned).
You could sell your old mobo/cpu/ram to help offset the cost. You could even still sell your vidcard, and get some good money for it and move to pci-e. Though, the card is still very capable, so if you want to keep it, go ahead.
Just to throw it in there, a good pure pci-e/ddr2 build would cost about $700 (E4300/GA-965P-S3/2GBNQ/X1950Pro/XClio500W). If you can wait a couple more months and save a bit more cash, then I'd suggest doing so, since new, cheaper Core2Duos will be out, as well as more affordable dx10 cards.
dailytech.com/article.aspx?newsid=5414
$500 for just mobo/cpu/ram-- Everything else I can recycle from my old system.
So the Core2 duos are best bang right now? I haven't looked too much at them. Thanks for the articles, they clarified much information on them for me.
Come to think of it, I am thinking in the long run I may just opt out to get a PCI-e board and buy a new video card after fleabaying some stuff laying around. Do all of the Core2 Duos OC well? I can muster up some more dough for a higher clockspeed one than the E4300, if that is, the others OC near as well. Also, I have a 500watt Enermax PSU, will that work fine in a new system?
Thanks again everyone. :D
How old is the Enermax?
Yes, all Core2Duos OC extremely well. 3Ghz is easy on any chip as long as the board can pump up the FSB, and the limit for air cooling seems to be 3.5Ghz with a GOOD cpu hsf. If you can, go ahead and wait. When you can't wait any longer, just post again and we'll see which parts fit your budget at that time. Keep in mind, it'd be better to build a whole new system (cpu/mobo/ram/hdd/gpu/dvdrw/psu, case is optional), so save as much as you can.
sell your PC for $200 and buy something for $700
i had a shuttle w/ 80HD, 1g pc2700, dvd-rw, fx5600, and amd xp2600
sold it for $250 and i bought a whole new set up , but it was $910 total. however, i bet you can sell your PC to someone (who does not know that much about PCs) and i bet you could get $200. hopefully. now, if you have a $700 budget then you can buy something better
