I need an ergonomic mouse and mousepad.
Celestial Avenger
Inspired by the ergonomic keyboard topic.
I need something for my right wrist, which was shot all to hell last year by a temp job that required massive amounts of 10-key data entry and an obscene amount of clicking and dragging of the mouse. I probably have carpal tunnel in the damn thing right now, or at least I am dangerously close.
I bought some sort of beanbag to go under my wrist for $10 last year. It hurt my wrist bad, which was the opposite of what it said it would do.
I bought a gel mousepad with a gel resting pad for my wrist for $20 last year. It hurt my wrist bad, which was the opposite of what it said it would do.
So, obviously I can't search for myself because I always end up buying crap that only makes things worse.
Help would be appreciated. Thanks!
For a keyboard, I recommend the Microsoft Natural 4000. It has padded wrist rests, a nice ergonomic design..
As for a wrist rest for a mousepad, I suggest going to Office Depot or OfficeMax or Staples or something like that, give them a try.
http://www.techspot.com/reviews/hardware/ergomouse_roundup/
maybe that would help?
They aren't conventional mice though. I think I read that using a wrist pad is bad. Also if you can use your whole arm to move the mouse instead of the wrist that would help. But I realize that's literally impossible if you're gaming or something.
ho-man those things are expensive.
I can just game with a regular mouse when I need to, but these days I'm mostly using the computer for video editing.
I'll look into getting that keyboard as well. Thanks
As for the mouse, have you looked into a trackball? It would seem to me that a trackball would cut down the movement of your wrist, just using your thumb for tracking. I am not an expert though so YMMV.
I have a gargantuan trackball I found in the attic one day. I'll mess around with it for a week or two and see if it works for me. Thanks
I used to recommend the Microsoft Trackball Explorer (big ball), but they've discontinued it. If you can find one, try it out. holy crap, I just checked prices on ebay, and they're goin for 5x the price I used to pay for them.... WOW! http://search.ebay.com/Microsoft-Trackball-Explorer_W0QQfkrZ1QQfromZR8QQsubmitsearchZSearch
These are rather expensive as well, but work nicely: http://www.ergodirect.net/index.asp?PageAction=VIEWPROD&ProdID=235&gclid=CObat5Cwn4oCFRNGGAodqEiYmg
My friend uses those ergorest armrests, and they're so damn comfortable to use. Though, since they're so expensive, I just got a corner desk, so I can rest both of my arms on them instead, lol.
I'll look into getting a Trackball Explorer somehow.
I'm not sure if I have room for the armrests. My desk is extraordinarily small and curves inward. It's really a laptop desk but I'm using it for my PC and LCD anyway.
CA, I highly recommend the Kensington Expert Mouse trackball. No, it's not cheap. But I have been living with carpal tunnel for years and it has really helped. My hand will start to hurt after only a few minutes of using a regular mouse. mota has an older, non-optical Kensington and he games extensively with it.
Also, learn to use keyboard shortcuts as much as possible. In most programs you can access menu commands by using the keyboard instead of the mouse. For example, in IE if you press the alt key it will underscore the letter in the menu that you press to bring up that menu, so alt "t" for Tools, then "o" to bring up Internet Options. Takes a little getting used to, but it really saves your mouse hand and is actually faster. :)
