I Need a water block for AMD 64
kirk
I need help to choose a CPU water block for my AMD 64 3200, I am looking at getting the koolance exos, but I dont know what water block to get.
can some one reccomend me some??
Thanks
I'd recommend the TDX. It is around the RBX and WW but only has two hoses to connect. You can get the A64 top that goes on it.
I would recommend researching water cooling and building your own setup. The koolance exos runs on 1/4"ID tubing from what I understand. The TDX typically runs on 1/2"ID tubing.. sometimes 3/8ID tubing.
I think 2fresh has some nice heatercores.. bonnevill 77 with shroud and fans for around 50. An all around decent pump is the eheim 1250 but it is a monster... the mag3 is good but requires modification... and the swifty pump is nice. You can pick up a bay res for around 30 or just use a T section for filling.
I just think surfing the h2o forums and reading stickies will really help you out.
Some good websites are dtekcustoms, dangerden, cooltechnica, xoxide. I bought most of my stuff at dangerden and on the anandtech forums.
