I need a SLI board....
computerpro3
LightningRod
I just hopped on the GTX 280 SLI deal so I'm going to be back in the SLI game for the first time in a while. I'm really out of date on this (last time I did sli was 8800gtx), so I need some help.
I haev an e6800 that's running at 4ghz and 4GB or corsair dominator pc1066 ddr2. What are my options as far as motherboards go? If I could get an Intel based chipset that could run SLI, I'd be in heaven. I really don't want to deal with the nvidia ones. I don' want to pay $300 for a motherboard either though. What are my options here? The most important thing to me is stability (and compatibility with my memory). Second is overclocking ability.
Thanks for your help.
With that cpu ur limited nividia chipset only for sli or go to x58 fo intel thats it cut and dry which means new cpu and mem and mboard.
Considering the 280's are faster and cheaper, I don't want to do that. The 295 tanks at 2560x1600 which is what I game at.
2 280s is about id say 10% better than the 295 but you get the 295 in quad it rocks which I am doing right now. Gonna step up one of my 280 for 38 dollars and then going to purchase the other 295. Then send my other 280 to my son win win for me.
I would not do that as it shows that 3xGTX280 is better the higher you go/ad eyecandy, cheaper to as it only sets you back what one card cost with is at almost right price now.
The ASUS P5N-D is a stable, inexpensive Sli MB which fits your specs. The E6800 & your Corsair Dominator 1066 DDR2 will drop right in.
I understand where you are coming from definately but was looking to get my son out of his 8800Gtx to something a little better and not having to hack the case of the 1200 but thats no big deal. In the long run it would be easier 2 buy 2 280 price wise now and run trip sli. And obviously I dont think the 1000 quatro would handle the trip sli even though it says it trip 12 volt rails. Ya thoughts er let me know. not meaning to highjack thread sorry bud.
I was curious about what you said about the Antec TruePower Quattro TPQ-1000 ATX12V because I have two of them. Check out this link and see if it helps you. See pages 1-5.
http://www.overclock3d.net/reviews.php?/power_supply/antec_truepower_quattro_1000w_atx_psu/1
If you look at that review they said the max they could get was 919 on it. Now if you look at the sticker closely. It say max output 840, you are seriously cutting it close at max output of 840 for trip sli gtx280 or all ready over that. Now if you are like me I run nothing but ssd and 1 seagate 7200.11 1tb drive for backups and what have you. With the ssds you draw quite a bit less power than conventional drives so with a max output of 840 should almost be possible to do the trip sli. I guess i will just have to try it actually and just see with all the 9 fans in my case and 3 gtx 280 the i7965 pumping @4400 it will still be cutting it close with my setup. And lets say if u have convetional drives say power hungry raptors say 3 or 4 I dont think you would really be able to do it and if you did. it would be cutting close on the max outp of 840.
I thought I would let you draw your own conclusion. True output means everything, my first Sli build a couple of years ago was a major flop. I sent two motherboard back before I figured out my 650w PSU was under powered. After researching this PSU I found the true output was only 480w which wasn't enough to power my system. I settled on the 1000w Antec which was an overkill at the time but I never wanted power to be an issue again, not in the near future anyway.
I can tell you this for certain: The TPQ-1000 is easily capable of powering three GTX280s in triple-SLI. The "maximum output" of 840W is actually the maximum for the 12V rails, but the PSU can supply 1000W total when the other rails are loaded to 160W. And the reason that review was only able to load it up to 919W was because their testing equipment was insufficient. It had nothing to do with the PSU itself.
