I need a right angled power plug
updawg
I replaced in the 150 Watt psu in the antec isk case with a 270 fortron 80 plus. However I need a right angled psu cord but have come to find out that I can only find them pointing in one direction, opposite of what I need. If anyone can provide any help I would be greatly appreciative. I attached a picture to aid in understanding.
If you are prepared to pop the lid on that PSU you could probably rotate the connector or just bypass it completely.
I've seen a rewirable one that you could change the direction on but it was ages ago and i'm not sure where I saw it.
I know silverstone uses 90deg adaptors in the same direction with their FT03 and RV03 cases...
PW...good advice.
Are you sure the power supply isn't installed upside down...:D. Just checkin...
You've got things pretty well crammed in there, how about a pic of the whole set up?
LC
i would say a small rewire job will fix this problem. looks like a nice idea
Jen
Thanks for the response, I could open up the PSU or I could just flip it and get a right angled connector that only seems to come in that orientation. The one shown on monoprice would just angle down into the bottom of the case and not work. Here are some more pictures as requested.
Antec ISK 310
Panasonic UJ130 Blu Ray
H55N-USB3
I3-550
G.Skill 2x2 1600
OCZ Agility 2 60GB
Hitachi 500 GB 7200RPM
Sparkle GT 430
Fortron 270 80+ PSU
Wow thank you so much. I ordered the extension off of buy.com. Thanks again!
