I need a PSU "Y" cable
Kil4Thril
Not the normal one. I need one with 2 equipment ends (female), and 1 US 3-prong plug. Is there something like that out there, or am I going to have to make it myself?
I'm pretty sure there aren't any cables like that, nor would it be a good idea to use one since the cable might not be rated for the amount of current that two PSUs would draw from it.
Hmm, not bad. Well, if you'll be running LCDs off of it, that shouldn't be a problem.
Well, I'm actually wanting to do 2 monitors, but the same cable will work. I have actually found 1- http://www.bhphotovideo.com/c/product/371083-REG/Hosa_Technology_YIE_406_YIE_406_Edison_to_Two.html
Since your monitors are likely to be further apart than the adapter you found, you may want to go with this:
http://www.cyberguys.com/product-details/?productid=12696
You would need a regular power cord to go along with it.
http://www.cyberguys.com/product-details/?productid=4780
CyberGuys is awesome, and I've ordered tons of stuff from them in the past.
Cheers.
