I need a power supply
wookiewoof
I read the sticky.. Before Making a Thread About Buying a PSU. I think it has made me more confused.
I am at the moment looking for a modular type as my case is small...gets smaller every time I open it up. I can't decide on the Antec/modstream/Superflower. A kick in the right direction would help.
However I am thinking about modding my case by creating a enclosure the same length and width of my case but only about 4inches high.
I would put the PSU in the enclosure and mount my case to the top of it and run what wires I need up through the bottom of the case and the hole where the PSU is suppose to be would be an exhaust. For this scenario I am thinking of getting an Enermax. But whatever I get I will want a 20pin connector..or if it is a 24pin..one that the extra 4 pins will slide off.
Comments on either scenario will be appreciated.
Or you could just buy a Stacker and use the lower PSU bracket...
