I need a Power Sander
agentzero9
Can anyone recommend some sanders I should look at. This will be for normal case moding (taking paint off the case) as well as for furniture etc.
I was looking at this unit at lowes (home depot also has a similar model though I'm not sure if there is a difference.). Is orbital the way to go? What about replacement discs, are the expensive? Should I go for a different type of sander alltogether. Any input would be helpful. :D
don't forget about the cost of the sanding pads as that can add up aswell.
codeflux said:
it's not a POS - it works, and works well. i am not saying that you can't get better, but the Mouse sander is good enough for occasional use.
the mouse sander is weak. i would like to see you sand down a table top or a bed frame with that lol. a random orbit sander (of any kind) is going to be 100X better than the vibrating mouse. hook a vacum hose to the r/o sander and your sandpaper last much longer since you don't gum up the paper and you keep the amount of dust flying around down to a minimum. If you are going to spend money on a tool why would you waste it on a toy like that mouse when you can have a Porter Cable that will last you for years to come? I know it costs a lot more but with power tools, you always get what you pay for.
mouse = toy
r/o sander = tool
/rant
Thanks for the links, and the reviews at amazon have also been helpful but have also brought up some new questions.
Can anyone tell me which is better: adhesive-backed sanding discs, or the hook and loop discs? Each orbital sander out there seems to come in 2 models, which is better?
