I have a feeling that my PSU is either bad or doesn't have sufficient power. Even if that is not the case, I would like to upgrade. I'm just looking for recommendations (I read the sticky but it's like a year old).
It needs to be compatable with my current setup [see sig.]
It needs to be compatable with my future setup - AMDX2/Intel Dual Core
It needs to have enough power for SLI/Crossfire
It should be reasonably quiet
I plan on getting an Antec P180 case, which I am under the impression it works best with a PSU with longer cables.
Lastly, if it is pre-sleeved and has the quick connect cables (or whatever they're called), that is preferable.
I'd like to spend less than $150.
