I need a new LCD! Help!
melomania
I currently have a RealSync 17' LCD (not sure of model) that I am using for gaming and watching DVD's. I have had it for a year and it's been good to me.
I decided to get a second 17' LCD monitor but I am unsure of a 'quality' model. I know Viewsonic makes some good ones so I was checking out the VX724. I need something good for gaming but no more than $300. If there is a good 19' LCD for a deal I would also go for it too.
For the past week or so I was thinking about getting a 26' Panasonic PureFlat HDTV Monitor (not an LCD), but I think that a new LCD monitor would suit me fine.
The video card I am running is an Nvidia6600GT through DVI.
I also HATE cutting when I'm playing games, which is why I enabled vertical sync, but I have notice that my mouse seems to have some 'lag' to it. It is like it is delayed?
Comments? Suggestions?
I don't know but I may be in the same boat as you. I need a new gaming monitor possibly except that I dont want to spend over 250. Im not sure if I really want an LCD, I may just get a 19" crt.
A 19" widescreen LCD perhaps?
ViewSonic VA1912wb
Alternate merchants
BTW, that "26' Panasonic PureFlat HDTV Monitor" is not capable of that high of a resolution. Not really sure but i suspect 1024 X xxx max, and that might even be scaled to an even lower resolution. Crt televisions don't make the greatest computer monitors.
Edit: or maybe consider the FW900 24" widescreen crt: http://www.hardforum.com/showthread.php?t=952788 (1920 x 1200 @ 98hz)
ViewSonic VA1912wb
Alternate merchants
Go here to see me and Tiny's thoughts on that Viewsonic that he posted......
http://www.hardforum.com/showthread.php?p=1028626414#post1028626414
melomania said:
Thank you very much for your input Josh. I have never considered that before! I really like that viewsonic a lot and never really thought about going widescreen. Would a 17' and a 19' widescreen work out fine?
I think that would look great. I would love to have a duel monitor setup.........
