**I Need A New Card/Im Clueless!**
Its been a while since I bought a new card, last cards I bought were 4600, and a 6500 series, Im building a new rig, an Abit AN9 32x, and looking to buy 2 cards for SLi, that can handle todays games and some older ones.........nothing too expensive, as I dont game heavily but want to again.........what do you guys recommend?
Thanx for any help!:)
Well, there are a LOT of choices... we'll need more info on "not expensive" though. How much ya lookin to spend?
Don't go SLI, just take the budget you were looking to spend and get a single, better card. If you're working on 1600x1200 or less, go with a 8800GTS 320mb.
your buying a sli 32x board,but you dont want to spend alot on video cards.....that doesnt make sense at all.
Yea there are rarely (never?) cases where having two inexpensive video cards is going to be better than a card that costs as much as both of them combined. The only SLI setups that have any real value over a single card are top of the line 800$+ setups.
From my obsevations it seems like SLI setups in general don't start to shine unless the resolution is cranked up. The problem is the value/midrange cards you generally don't have enough vram on the card to support a huge resolution (1900x1200+)- since the amount of vram available in SLI does not double (IE two 256mb cards still only use a 256mb framebuffer). You can also end up with cards that do have enough memory, but its some slow DDR2 stuff and the GPU is so weak that it would render a 512mb scene as a slide show.
In some cases with cheaper cards you can get close to the same performance per $ as a single card, but you will be paying some extra for the coolness of having 2 cards. the upcomming 8600 series seems like it would be the next cadidate for a entry level SLI system since it supports DX10.
Donno - I personally think that the 8800 GTS 320MB is an absolute bargain (well in the UK it is anyway) for the performance that it offers, as for the USA and Canada it is still a VERY good performance/price ratio.
But maybe if you can wait just a bit longer (a few months) then you can wait untill the R600 launch and the midrange G80's - this will make the prices plummet down with the DX9 video cards and the newly released mid-range DX10 GPU's will offer quite good performance/price ratioas well - so it's your choice whether to wait or not, if not go for the 8800GTS 320MB.
Hope this helps a bit. :)
Thanx for the info guys, I got a good deal on the mobo so I couldnt paas it up.......I dont mind spending the money, what I dont want is to buy 2 $500 cards.........
