I need a laptop for college.
rusmofat
I have never owned a laptop before.
I really dont need by big gaming rig anymore, so I'll probably end up selling it. I think I want a laptop with one of those widescreens so I can watch DVDs, that would be really cool. I also have a huge music collection, how are laptop harddrives? external harddrive attachments? I need to be able to connect a printer, my nice klipsch speakers for audio and i need to be able to plug in a regular mouse, i hate the mini mice and the built in one.
I know absolutly nothing about laptops. I just need it to be around 800-1000 dollars, i need to have 512 or 1024mb of ram (could i buy one with 512 and then upgrade to 1024?) I need it for all my multimedia needs (except gaming) and I need it for schoolwork.
Which do I need? A Dell? Toshiba? I really have no idea what is good. Please help.
Well, I can't give you any reccomondations off the top of my head but I'll try and answer some questions for you I guess =)
You can, of course, watch DVDs on a non-widescreen laptop in 4:3 aspect, but I'm sure you'd enjoy the widescreen experience if you're already leaning that way... It's a personal preference IMHO and I tend to agree with you on it ;)
Laptop harddrives are... well, let's just say they're smaller and TEND to be slower. A majority of laptop drives are 5400RPM (as most older desktop drives were) however you can find 7200RPM drives without too much trouble. You'll experience slightly better load times and whatnot but of course you'll also be spending more. Capacity wise you'll be hard-pressed to find a laptop with anywhere near the storage capacity of most [H]er's desktop rigs but if you're not filling the drive with a ton of games then the 60+gig HDDs should provide enough storage for you.
I haven't had a lot of experience with the external drive enclosures but when I have used them I haven't had any issues. USB2.0/Firewire handle well enough for the application. I'll let someone else give you abit more info about them.
Print connections should be no issue.
The onboard sound in most laptops tends to be lacking and hooking up some nice Klipschs to it might hurt your ears... for another $100 or so you can get an Audigy2 PCMCIA card for the laptop to more fully enjoy your setup.
As long as your mouse is USB there's no issues there... if you're addicted to your ancient PS/2 mouse... well, you're not so it's not an issue ;)
256 megs of RAM is as low as you're likely to find. 512 is fairly common and 1024mb is becoming more and more frequent (although not so much in your price range). RAM is pretty much the easiest component to install/change in a laptop by far... no problem to upgrade down the line.
Good luck finding something that suits you and I hope I managed to at least answer a few questions you had.
Acer TM4402WLMI
http://www.newegg.com/Product/Product.asp?Item=N82E16834115196
Has a 100gig hard drive
512mb RAM (upgradeable)
Turion for 64bit if that type of thing interests you
AND it has the ATI x700 just in case you want to fire up the very occasional game you can do so
Dell Inspiron 6000
http://configure.us.dell.com/dellstore/config.aspx?c=us&cs=19&l=en&oc=i6000S1&s=dhs
I would suggest upgrading to the Pentium M 740 to get the 533 FSB
I would also suggest upgrading to the ATI x300. That way you are not sharing system RAM.
There are a plethora of options out there. These are just what I would buy should I be in your shoes. Good luck with the laptop hunt. :D
