I need a good VGA cooler
SilentScope
http://www.newegg.com/Product/Produ...N82E16814102666
The above is my video card, a sapphire x1600 PRO. The cooling fucking sucks on it, it idles at 60*C, and udner a laod goes up to 70*
My case is quite cool along with my CPU, so I just need a cooler for this. I need something that is kind of easy to install, and it can't take up more than 1 extra PCI slot. Any suggestions? I want to keep this kind of cheap too.
Also, the ATITool won't let me change fan speeds...why? The panel doesn't even show up for it.
Zalman VF-700Cu would be perfect for it. If you don't want to spend that much, the AlCu would be good too.
your temps are really not that bad , i have a 7950 and it was running at 77c on idle and 89c on load .
I stuck two fans over it and now things are very different , 56c idle 74c load.
The money you have save it and put it at a side or buy a radiator (watercooling)and invest towards that, the chances are you will probably upgrade your 1600 in another 6 months time and you will not be able to use the graphics cooler.
Its your money and only you can decide.
VF-900 - shipped free for $34 at NewEgg!!!! CRAZY deal on this top of the line cooler.
Lowest price ever.
I need one for the 7950 and i talked to mr .Huber of arctic cooling and he said you will hopefully see one in late august . Its something which my card needs or its going to be watercooling. Need to do some research though.
Is there a recent thread where you haven't mentioned your 7950? :rolleyes:
OP: The Zalman VF700Cu would be a great cooler for the x1600 but if you can get the 900 instead for same or touch more then get the 900
No amn i am sorry but the card is so good and hot and when i decreased the temps. dude i was proud.
One day you will see the beauty of this .
The reason for this is that i find these coolers a wee bit overated and i have noticed people buy a card which say £120 and then they buy a £35 cooler but if they bought a £155 one, then underclocked the card a bit it still be quiter and cooler than the last card not forgeting faster, nothing else.
So sorry it was important to mention my card and using just two 120mm decreased thetemps by 30%., it does me proud. ;)
also i have been to lazy in doing a sig with my pc parts like you have , you have nice things too i see.
