I need a beating
Daywin
So I ordered everything for putting my system underwater, and I got everything today.
I ordered primoflex 1/2" x 3/4" hose and 3/8" x 1/2" compression fittings lmao
So I had to order the right ones today, but they won't be here for almost a week. Patience is not my cup of tea lol
I guess what I am gonna do is use barbs until then with some zip ties.
Whats going to be the easiest way to drain an xspc combo pump/res??
I don't think zip ties are going to hold that very well... and you better hope none of them break.
Zip ties won't be necessary lol. Especially if you'll only be using the barbs for a week.
As for the pump/res, I'm assuming you mean the bay res? There are a number of ways to do it. I believe there's a fill/drain port on top that can be used (can't remember if it's g1/4 or not, never owned a bay res.)
