I need a 40" touch screen overlay
dalearyous
anyone recommend a decent 40" touch screen overlay? i can't replace the display unfortunately. an overlay or a corner to corner device would work. thoughts?
Haven't used one myself but after a little searching: PQ Labs G4 Multi Touch Screen Overlay 40 inch
Perhaps that would fit the bill? Not very cheap, though. If you are looking for firsthand recommendations I can't give any, but figured this might point you in the right direction if you hadn't found these before.
