I need a <$250 video card
pr0pensity
I'm upgrading from a 6800GS and may want a silent cooler. Nothing dual slot. 7800GT? Are any of the X1800 series in that range?
You can geta 7800gt used for that much ;)
Ther I'd reccomend a 7600gt, x850xt, 6800GS, and on down the line :)
I have a 6800GS. How does that compare to the 7600GT? Are there benchmark sites?
I see a LEADTEK 7800GT 256MB 7800GT TDH MY VIVO EXTREME EDITION for $250. Does VIVO mean bad?
quietRiot said:
vivo= video in video out
vivo=more multimedia possibilities
So it's a capture card? And there's no hidden agenda with the "Extreme Edition" tagline? I may get this one.
without heading to newegg to check, I'm assuming leadtek's Extreme Edition is probably just clocked higher, like eVGA's superclocked models and XFX's XXX editions. Having said that, I too feel that a 7800gt is the way to go.
If you're looking to spend around $200-225, then the XFX 7600 GT XXX edition is the one you want. It will outperform almost all the listed cards here.
Not a 7800GT
Not a 7900gt
a 6800gs, yea :)
buying a 7600GT isn't gong to be nearly as nice of a jump as grabbing a 7800GT new or used...for a tiny bit more you'll have significantly better performance, and it will be better value.
or on the ATI side there are 289$ 256MB X1800XT cards. I wish we could see a 256MB X1900core for around 350$. Personally that would own completely and I would buy it in a heart beat.
6800GS sounds pretty good already, why are you upgrading? I'd wait till DX10 comes out, pick up one of those cards, it shouldn't be long.
B/C the new elder scroll game is a killer as far as preformace goes
:p
:p
The question here is; What monitor are you using? If you're happy with 10X7 then you're fine to go. If you want 19X12 then go for 7900...... in SLI!!!!!!!!!
10x7 is still hefty for the 6800GS in Oblivion, I spent several hours trying to find a measure for looks/performance last night, still havent reached it. The game still looks incredible, but if you want serious performace and eye candy, a 6800GS just doesnt cut it.
