I may have a slight overheating problem
lol try touching the cpu heatsink, see if its actually that hot
could just be bad sensors, short of having 0 ventilation and a totally passiv system that has to be hard to achieve, you could fry eggs on the top :)
That CPU will shut down automatically at 85C, so the reading of 92C was certainly false.
I couldn't find any info on when (or if) that GPU automatically shuts down, except for a few comments that readings of more than 80C were considered extreme. I can't imagine it would run at 103C.
You have to be careful, the heatsink might not be making proper contact with the CPU so the heat would not be tranferred across.
Yeah I looked up the CPU and the maximum temperature its suppose to survive is 85.
I either have a AMD 2500+ or an AMD 2600+ . Everest (really old free version) says its a 2500+ but its running at 2600+ speeds with an 11.5 multiplier.
I can't seem to be able to change these temperatures. I have opened part of the case, and have placed a $12 box fan over the entire area in an attempt to do something. However, no matter what I do with the fan , the temperatures stay the same. I can turn it off, turn it around, place it on half the case ... and get nowhere. Most I could do is maybe 2 degrees lower to the idle CPU. I didn't see decrease in temperatures to the GPU. I have underclocked the GPU as it shoots past 110 on stock clocks.
I expected the fan to do a little more. I can push tons of air in .. .and nothing happens... I can push tons of air out ... and nothing happens.
CPU is maxing out at 72 now ... so that is better. GPU is still a mess.
Would the power supply supplying 13.2 - 13.7 (yes it varies that much) volts on the 12 volt rail be related to the heat ?
I had this problem yesterday with my Athlon XP 1400+ Chip. It also read 92C in the BIOS. The automatic shut down happened twice and it must have been >100C before it shut down. I touched the heatsink and burned my finger.
Anyway, I redid the thermal compound and it's down to 50C.
:edit: spelling
it's definitely possible for them to read that hot, very good you keep an eye on them.
When the Crysis demo first came out, I was shocked to find my GPU reading 125+ C !!
I shut it down, cleaned all the dust & debris from its heatsink&fan, after which it was playing the exact same crysis demo without breaking 80C :)
keep it clean, & as others stated check the contact patch, thermal grease & trueness
Would the power supply supplying 13.2 - 13.7 (yes it varies that much) volts on the 12 volt rail be related to the heat ? [/QUOTE said:
wow, thats pretty high, I would get a new power supply.
1.7/12 = 15% thats way out of spec, and could be increasing the voltage to the processor, and causing higher temps.
I cleaned a ton of dirt off my CPU fan and heat sink and what I would call a small amount of dirt from the X850XT's copper heat sink and the heating problem is solved. CPU is ideling at 50 ish with a peak of 58. GPU peaks at 70 with default clocks at 30% fan speed in atitoo
The reason I questioned the 92 reading is this processor is only designed to sustain 85 degrees.
Never fully trust sensors. If something seems odd, it is. I had a sensor that use to report my CPU was sitting at -35 degrees Celsius. I am pretty sure my CPU wasn't below freezing point in a regular room temperature.
