Alright so I got two new 2TB drives and I copied everything from two 640GB drives to a 2TB mirror. After reading around I removed the mirror and from what I could tell had 2 fully functioning drives. I then copied all data from my 500GB drives to the 640 drives.
At this point I removed the 500's from the system and got the TB drives into my case. The 640's were in mirror when I shutdown, one went into an external, one internal. I get back into the system and I had missing drives. So I tried to get one of the 640's to work (not thinking) and ended up having it converted and it started a format...f^ck...
Alright so I have 1 2TB drive that is working, the other says missing along with the 640GB drive. At this point, I don't care about the second 2TB drive as I can copy all back to it later but how can I get the data back from the 640 drives?
If I right click on the missing drives to do a "reactivate disk" it does...NOTHING.
HELP?!
Edit: in computer management:disk management it states the second 640 as 100% free, but missing.
Edit 2: I guess I can just attempt a recovery using GetDataBack for NTFS :|
HELP?!
