I love comouters =-(
I have had a few problems with my comp lately. The motherboard blew and when it did the comp just went bad.
First problem i got a new mobo, and Vid card...everythin hooked up nice installed windows, after installin the mobo drivers and such, the computer would get the typical blue windows error screen. I waited for a new copy of windows to come from microsoft, tried that same problem.
Well i installed the drivers over the internet yesterday, works ok now BUT. I can start the computer it runs pretty damn stable (i get a unable to display XML thing on some websites, but very rarely. But i tried to install WoW onto my computer like 5 times. What it does is i insert the disk, than go to my computer and click on the drive, the computer displays that same blue error screen again, and than freezes. What is weird is it only happens when you put a disk ointo the cd-rom.
BTW: I have tried 2 Cd-Roms, 2 Ide cables, both slots, and combinations of the Master slave, primary secondary IDE slots on the mobo. Oh and a new mobo too, actually 2 of them
Any Ideas? i wann get this thing runnin before the expansion of WoW=-D
What are your CPU temps under idle and load conditions?
Also, have you tried a different power supply?
The temps on the cpu are fine, i checked em, nothin ab normal. I havent tried a powersupply but i dont know how that could lead to the blue error screen.
go into the windows system logs, and see what kinds of errors are being logged. To help pinpoint what windows is crashing on. It sounds like your memory. Try running memtest86, by using a DOS boot CD.
well i tried using new memory, that actually didnt do anything for the problem. I dont know how to get into the logs, and i tried the dos boot, didnt work =-(
Have you tried a google on the error codes?
Sounds to me like when your original motherboard died, it may have done some other damage. Try to get the error codes off the BSOD, or when windows reboots, it should let you know that it recovered from a fatal error, you can get the info from there as well.
I'd be willing to place a bet on bad ram.
yeah check memory and powersupply in your comouter. It sounds more like powersupply, because when your comouter comes under load it crashes, that can happen when your CPU is thrown fluctuating voltages.
well I tried the ram, actually its a ram that works perfect with this motherboards compatibility, because it was used ont he exact same model and board, and it still gave me the error screen. The only thing left really is the PSU. I called windows, they told me that the error is hardware related. So is the final suggestion PSU?
another reason why im guessin it isnt the PSU also is because the computer runs mint right now most likely, zero lag...Also it takes awhile for the cdrom to ever power up, another PSU issue i imagine?
• You are running the processor or mainboard beyond its specifications. For example, you are overclocking the processor or bus. We recommend that you run your hardware at the manufacturer-rated speeds.
• Noisy power, overstressed power strips, outmatched power supplies and failing power supplies can destabilize your computer. Make sure that you have a stable, reliable power supply to your computer.
• Extreme thermal conditions caused by the failure of cooling devices such as fans may damage your computer. Make sure that your cooling devices are all working.
• You have damaged memory or memory that is not the correct type for your computer. If you recently changed the memory configuration, revert to the previous configuration to determine what is wrong. Make sure that you are using the correct memory for your computer.
is your cdrom running at udma mode 2 or at some pio speed? go into the device manager and check out your ide ata/atapi controllers to make sure you are running at the right interface. i cant tell what mainboard you are using. make sure you have the correct chipset drivers installed.
go into control panel
click admistrative tools
click event viewer
click system
check out any errors. follow the links to the ms "help" pages. or google the error codes.
click applications. do same as above.
so did u ever try a new psu? and sometimes when stuff like mobo's getin fried, cant it affect the harddrive, just a possiblity. i would try everything. so try new hdd and new psu
Did you run memtest? You have to run memtest86 booted to DOS. Those windows errors indicate memory errors. I bet the farm, it's the memory. Test only one chip at a time.
i tried putting in ram that worked perfectly with the exact same mobo and it did not solve the problem. I didnt try a new PSU yet, im going to buy one tomorrow.
this is the list of Parts i have swapped in and out to try
-IDE cables, different slots and slaves.
-3 different harddrives.(2 being new, 1 being brand new)
-new vid card.
-new mobo.
-new cd rom.
-ram
the only thing really left is the psu
and what is Memtest, ill try anything at this point, even though i dont think its ram
ok wow seriously. y go threw buying or getting all that, and end up not working! that hella sucks, im sorry dude! but seriously y not buy a new cpu?! ur old one could have been ruined in the frying.
i didnt really waste any money (besides the graphics card, but i wanted to upgrade.) everything that got replaced was junked....Im going to buy a new PSU tomorrow.
ok thts cool. man u r a trooper!! lol i give u major props! i just bought the e6300 and ecs mobo combo and it wont detect my video card, and im gettiong so pissed i wanna throw it in the pool and i only got it saturday night! lol i hate via!
One more thing to try before purchasing new PSU, try Metering your old PSU.
Personally I would Mulit-meter my PSU. ( iirc you short the Green wire to the any Black wire on the 24 connector using a paper clip or what have you ...can someone confirm green to any black, sounds right but too early in the am for me)
If its reads good then
run Memtest.
as you can tell even though i know some stuff about comps, i dont know it all, which one do I want to download off of the website?
use v1.65. if you dont have a floppy, download the first .iso file and burn to cd. if you have a floppy download the pre compiled binary for dos/win (floppy)
i got the PSU..the one i actually got seemed to be shizzy =-/ i dont thinki have good luck at all.
Anyone in the fall river mass. area that can possibley help me.
list the PSU, name, manufacturer, and specs.
also, you still need to run memtest. Just find a cd burner, and create a bootable cd. run it for at least 1hr.
i have tried a burner and regular cd rom....you can NOT use it it doesnt work...and i tried working ram today...no luck...thermaltake 480 watt.
yup tried all the slots and so on...i think im gonna end up getting somethin off of newegg =-/ i might buy a 475 watt one in the city first to make sure its the problem. Newegg is a painwith their returns
As much as we don't expect a power supply to be the culprit normally is the problem. Don't think just because a PC has power coming in and the fans are spinning that the power supply is working fine. This happened to me and just a simple power supply swap fixed the problem.
I take it you have not metered your PSU? :rolleyes:
Well your cash I guess LOL. Let us know :)
It could be the power supply that killed everything though.
actually i think it was a mix of the powersupply, and the cathode that i just found out was shorting out.
I dont know how to meter my PSU so i dont know how to do that.
gone to a few places, working contantly its hard to have more than a few free hours a day, usually to sleep lol...im going to try staples and best buy tonight.
This doesn't really sound like a psu problem at all. I'm thinking more along the lines of chipset drivers and/or maybe a bios flash. Goto your mobo support site and make sure you have all updated drivers.
Could it be a bios update is needed? I had one motherboard one time that just wouldnt work(load windows) until I did the update.
